Activity Forums Apple Final Cut Pro Exporting MP4
  • Exporting MP4
    Posted by Brian Thomas on June 1, 2020 at 9:28 am
    Really dumb question here… I have some MP4 files which were created when converting some VHS cassettes using an Elgato device. I’d like to use FCPX to cut off a few seconds/minutes from the start and the end along with odd bits here and there and maybe add a couple of titles. Normal export gives me a massive (by comparison) .MOV file. Is there a recommended setting for the “Share” to be an .MP4 while keeping the exported file at a comparable size (as the original)?
    Near Geneva, Switzerland
    Brian Thomas replied 6 years, 3 months ago 3 Members · 5 Replies
  • Brian Thomas
    June 1, 2020 at 9:35 am
    OH… I think I may have answered my own question. I exported using “Apple Devices 720” which (after a long time) gave me a .M4V file of about the same size as the original .MP4 file. I changed the file type to MP4 and Quicktime had no problem playing it. Would this be the way to go? Many thanks in advance for any advice here.
  • Eric Santiago
    June 1, 2020 at 12:55 pm
    When I use the h264 version I would get the .MOV suffix so I just change it to .MP4.
    I think its the same but most of the time the file gets uploaded and converted on the host platform.
    If its a delivery file (to another client Mac/PC), I would double-check if they can open an .MV4 file.
    At that point, I usually don’t export low res from FCPX.
    I go ProRes > AME > delivery format e.g. h264, avi, wmv, etc…
  • Brian Thomas
    June 1, 2020 at 2:42 pm
    Many thanks for that Eric!
  • Joe Marler
    June 1, 2020 at 5:56 pm
    [Brian Thomas] “I’d like to use FCPX to cut off a few seconds/minutes from the start and the end along with odd bits here and there and maybe add a couple of titles.”
    Except for adding titles, you can do this with Quicktime Player, and it does not re-encode. This (1) Is vastly faster and (2) Avoids generational loss from re-encoding.
    It can both trim head/tail plus delete any number of sparse intervening ranges, all in a single editing operation.
    See the MacMost tutorial “Easily Trimming Video Files with Quicktime Player”: https://youtu.be/W7NrlhZin4M
  • Brian Thomas
    June 2, 2020 at 8:11 am
    WOW – this is just great! Thanks so much Joe – you have made this process so much easier for me. I’m now a ‘subscriber’ of yours.
