Activity › Forums › Adobe Premiere Pro › Exporting .mov with a MXF wrapper with audio 48KHz/8bit
  • Exporting .mov with a MXF wrapper with audio 48KHz/8bit
    Posted by Maurice Diaz on April 29, 2019 at 10:54 pm
    Hello, Maurice here,
    I am delivering files to a company in NY and they are asking for .mov files with an MXF wrapper with audio 48KHz/8bit.
    Question 1: How do I export an mov file wrapped in MXF using Premiere CC?
    Question 2: I understand the standard for audio in video is 48KHz/16bit. Why would they want 8bit? When I export the video with the audio at 8bit it has a lot of hissing.
    Any help is welcomed,
    thanks.
    Maurice Diaz replied 7 years, 5 months ago 5 Members · 12 Replies
  • 12 Replies
  • Tero Ahlfors
    April 30, 2019 at 3:50 am
    What are the EXACT delivery specs because “mov in an MXF” means nothing. If those are the specs you got it seems that they probably don’t know what they’re doing.
  • Bouke Vahl
    April 30, 2019 at 9:37 am
    I suspect the 8 bit is color depth, not audio bit depth.
    But I agree with Tero, if no codec is given it’s guessing.
    Bouke
    http://www.videotoolshed.com
  • John Pale
    April 30, 2019 at 12:54 pm
    This is insane. Mov (Quicktime) and MXF are two different types of containers. Many codecs can be wrapped as both Mov or MXF.
    Deliver them a beverage. Put it in a bottle and wrap that in a can.
    And they still haven’t told you what they want to drink.
  • Maurice Diaz
    April 30, 2019 at 2:54 pm
    I am still waiting for more specifics from them, but I agree with you. The specs they gave me are very vague, hence me asking here. I have to assume that the 8bit is either a typo or it refers to color depth.
    Thank you for your help.
  • Shane Ross
    April 30, 2019 at 6:32 pm
    John is spot on. MOV and MXF are containers…one a jar, one a can. They are asking for a can in a jar, but with no thing inside. XDCAM? ProRes? DNxHD? DNxHR? Those are codecs. You can deliver a ProRes MXF, or ProRes MOV…but not a MOV MXF file.
    Shane
    Little Frog Post
  • Bouke Vahl
    April 30, 2019 at 6:40 pm
    C’mon, give the guy a break.
    He HAS am .mov, and needs to go to MXF.
    It’s semantics.
    Bouke
  • Shane Ross
    April 30, 2019 at 7:28 pm
    [Bouke Vahl] “C’mon, give the guy a break.
    It’s semantics.”
    No…that’s not what it is. And it isn’t HIM we are riding, it’s the CLIENT.
    “I am delivering files to a company in NY and they are asking for .mov files with an MXF wrapper with audio 48KHz/8bit. ”
    The COMPANY who is doing the asking is the one that needs to provide better information….have a better tech person who understands this stuff.
    Shane
    Little Frog Post
  • Maurice Diaz
    April 30, 2019 at 7:32 pm
    Thank you guys. I have now another piece of the puzzle. For codec I can deliver either ProRes 422 or DNx145.
    I use Premiere on a Mac. When I go to export I can find tons of DNx flavors, but not at 145 megabits per second. So, if go with Quicktime and ProRes 422 I will end up with mov files, not MXF files.
    I just don’t understand why wrap a wrap in a wrap.
    Their concern is that the EVS they use is very particular.
    This client’s comunication skills are badly lacking. I’m starting to believe that all this is nothing but bad grammar.
  • Bouke Vahl
    April 30, 2019 at 7:41 pm
    EVS is a HUGE pain.
    It does accept QT, but only if the Reelname is omitted. (I have a custom version of QTchange just for EVS…)
    Please, post the EXACT text (copy/paste) of the clients request.
    (And, 8 bits ProRes does not exists, all flavours are at least 10 bits.)
    Bouke
  • Maurice Diaz
    April 30, 2019 at 7:51 pm
    Exact request from client:
    * Clips can be imported into the X File3 on the EVS.
    * .MOV files with an MXF wrapper are acceptable with audio 48KHz/8bit
    * CODEC must be either AVID DNx145.mxf or ProRes 422. It cannot play H264 files.
    * Frame rate must be 59.94 – not 60 or 29.97 not 30. EVS is very particular
    That’s verbetim.
