Activity › Forums › Media 100 › Exporting M100 quicktime files into Final Cut Pro 5.1
  • Exporting M100 quicktime files into Final Cut Pro 5.1
    Posted by James Mulryan on June 1, 2006 at 6:23 pm
    I can’t get my M100 files to import directly into FCP 5.1.
    Does anyone have suggestions?
    G3
    OS 9.2
    M100 7.5 xr
    QT 5
    Kieran Matthew replied 20 years, 4 months ago 2 Members · 3 Replies
  • Kieran Matthew
    June 1, 2006 at 6:44 pm
    Is FCP running on the same G3 as media 100? If not that system will need to have the Media 100 transcoder installed on it. It can be downloaded from the media 100 website.
    Hope that helps
  • James Mulryan
    June 1, 2006 at 7:34 pm
    Kieran:
    Thank you for the info.
    No FCP is running on an IMac intel, QT 7.0.4
    FCP 5.1
  • Kieran Matthew
    June 1, 2006 at 8:13 pm
    Ahh! Now, this rings a bell. This may be to do with telling either the transcoder or quicktime to use rosetta rather than the native intel code.
    There was a similar problem posted a while back regarding the software codecs and intel macs
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=4&postid=856716
    Perhaps the info there might help?
    K
