Activity Forums Apple Motion Exporting lower field footage
  • Exporting lower field footage
    Posted by Chris Hayward on January 27, 2008 at 2:41 pm
    Hi. I work mainly with PAL projects and most PAL DV is set to a default of lower field. When I export from Motion, even though I have it set to PAL settings, the exports always come out as upper field – I test it by dragging the clip into Final Cut and checking the item properties – always says upper field.
    I usually choose the lossless alpha codec when I export from motion but again, this always winds up being upper field. So what export option should I be selecting for the footage to look great AND be lower field.
    Chris
    Chris Hayward replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
