Activity › Forums › Adobe Premiere Pro › Exporting lossless video (x264 vs h264 and more!)
  • Exporting lossless video (x264 vs h264 and more!)
    Posted by Pierre-luc Boucher on March 17, 2017 at 2:37 am
    Hey there,
    I just finished editing an extended version of the MST3k Movie and I’m ready to export the final product. I exported some previews with the following settings:
    The short previews looked great with these settings, but I want to make sure the actual movie is exported at the highest quality (lossless or as close). The project was made from the original Blu-ray M2TS files, 1920 x 1080.
    • It’s my understanding that x264 is better than H264?
    • Is there an advantage to using Adobe Media Encoder instead of Premiere?
    • I might want to add an alternate audio stream later in an MKV. Should I export the video stream and audio stream separately?
    Hope this info helps you and thanks in advance!
    PL Boucher
    Pierre-luc Boucher replied 9 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Tero Ahlfors
    March 17, 2017 at 7:21 am
    [Pierre-Luc Boucher] “lossless or as close”
    H264 or x264 aren’t even close to lossless. You would probably want to use DNxHD
  • Pierre-luc Boucher
    March 17, 2017 at 1:18 pm
    Good to know, I wasn’t familliar with this codec. The reason I thought of H264 as the best option was this: when I demux the streams from an MKV made directly from a Blu-ray using tsMuxer, the codec for the video stream usually shows H264.
    Was I wrong in my way of thinking? I see DNxHD is made by AVID, so would it be compatible with Premiere?
    Thanks for your reply!
    PL Boucher
  • Tero Ahlfors
    March 17, 2017 at 1:53 pm
    DNxHD is built into Premiere. Blu rays support H262, H264 and VC-1.
  • Jeff Pulera
    March 17, 2017 at 2:06 pm
    PL,
    A very important question – what is the purpose of this export – what do you want to do with it? That will influence the choice of codec you choose.
    Is it for a MASTER copy, from which you can later export various formats, or do you want to post online, or…??
    Jeff Pulera
    Safe Harbor Computers
    March 17, 2017 at 4:43 pm
    Hi Jeff,
    The purpose of the export is to have a personal copy of my extended cut that’s comparable or indistinguishable in quality to the officially released Blu-ray, since my edit is meant to be an alternative to the real movie. The resulting file has to be easily played and shareable on a variety of devices (computer, TV with USB drive, Plex, etc).
    Once exported, it will not be posted online or re-encoded in different formats or burnt to disc. It will be a file that can be readily accessible to play on devices mentioned above.
    Hope that makes sense!
  • Jeff Pulera
    March 17, 2017 at 4:48 pm
    For the compatibility/playback reasons you mention, then .mp4 is the most standard format to use.
    Your current settings should produce a very high-quality result. You may want to uncheck “Max Render Quality” – that is only used for scaling, which you are not doing in this case, frame size is constant between Source and Export.
    Jeff Pulera
    March 20, 2017 at 12:46 am
    That’s good enough for me!
    Thank you both
    PL
