Activity › Forums › Boris FX Particle Illusion › Exporting Loop Problem – Save Alpha
  • Exporting Loop Problem – Save Alpha
    Posted by David Arcila on March 20, 2009 at 10:06 pm
    Hello!
    I did a loop following the famous loop tutorial, now i want to export that loop as a sequence of images (png’s) with transparent background, but when i export the images with the Save Alpha option checked Particle Illusion exports the entire timeline, but when i do the same export but without the Save Alpha option, it exports the way i like it (just the loop) but without transparent background 🙁
    I hope i made myself clear, if not, i could post images with a detailed explanation.
    Thank you
    David Arcila replied 17 years, 6 months ago 2 Members · 2 Replies
  • Alan Lorence
    March 23, 2009 at 10:19 pm
    So the only thing you changed was checking or unchecking “Save Alpha” — absolutely nothing else was changed?
    Alan.
    http://www.wondertouch.com
  • David Arcila
    March 24, 2009 at 1:51 am
    Alan, thanks for your response.
    That’s right, the only thing that changed was the Save Alpha parameter.
