Activity Forums Adobe After Effects exporting issues: URGENT
  • exporting issues: URGENT
    Posted by Malcolm Desoto on September 28, 2007 at 2:36 pm
    okay, trying to export a 30 sec spot. No matter what I do, it always stops at some point
    I have never had this problem before it is just with this project.
    I’ve tried all sorts of settings:
    Lossless, half res, Quicktimes, etc.
    Is there any way to fix this? I need to have this done in the next few hours.
    I have sheer video codecs and Sorenson at my disposal. Is there any way to export a quicktime ref or something to Sorenson and have that do the compressing?
    Thanks.
    Malcolm Desoto replied 18 years, 12 months ago 4 Members · 16 Replies
  • 16 Replies
  • Spaceman —>
    September 28, 2007 at 2:39 pm
    does it always stop at the same place in time?
  • Malcolm Desoto
    September 28, 2007 at 2:41 pm
    Also, is there any way to “flatten” your project? I know of Pre-composing, but just wanted to know if you could some how meld the layers together, like a video mixdown in an editing application.
  • Malcolm Desoto
    September 28, 2007 at 2:43 pm
    No Chiarman, I set it to export last night and previewed it this morning. IT stopped about one second later than previously.
  • Malcolm Desoto
    September 28, 2007 at 2:50 pm
    Also, could I “save RAM preview”? I can build a RAM preview of the project fine.
    Would this look alright?
  • Malcolm Desoto
    September 28, 2007 at 2:59 pm
  • Malcolm Desoto
    September 28, 2007 at 3:08 pm
    Should I change my previewing preferences from Adaptive Resolution to Open GL before I render the project? Would that affect it at all?
  • Kevin Camp
    September 28, 2007 at 3:14 pm
    have you tried setting the secret pref to purge frames at a set interval…? if ae has trouble purging the ram cache when it hits the cache limit it will often just quit the render…
    to get the secret pref, hold the shift key while selecting any pref (if you’re using a mac hold the mouse button the entire time while selecting the prefer, rather than using multiple clicks). then from the preference selection pulldown, select ‘secret’ (at the bottom). set the purge every xx frames to a number that is bellow where it was quiting/crashing… so if it was quiting at frame 120, set it to purge at 100 or so.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Steve Roberts
    September 28, 2007 at 3:20 pm
    Can you render to a TIFF/TGA sequence, then when it crashes, render again, but starting from the crash point this time?
    It’s a workaround for now.
  • Malcolm Desoto
    September 28, 2007 at 3:22 pm
    Good suggestion Steve. I’ll try that.
    Thanks for the warning Dave!
  • Malcolm Desoto
