Activity › Forums › Adobe Premiere Pro › exporting issues
  • exporting issues
    Posted by Alexandre Brandt on July 29, 2013 at 11:01 am
    Hello all,
    I’m having trouble to export 2 minutes from a sequence in HDV 1080p25 to H264 720p25.
    The sequence has only 1 video track and 2 audio tracks enabled. The video is a .mov file.
    When I export after a few minutes the export % bar is still at 0 percent and never moves.
    However, when I export 2 HDV footage in M2T files format (from a CF card) edited in one sequence, it takes about 10-15min.
    Maybe the problem might be the sequence settings ? It has the render bar in yellow. Its a re-import from an XML created by Plural eyes.
    The fact is that my footage is actually log and transferred in FCP to make a .mov file and then I bring it in Premier. That’s because its long clips of concerts and premier pro has not solution to merge files belonged to the same clip in a mac environment. It also offers not solution to Log & transfer, from a CF card to any other format in fact such as Prores.
    Maybe premier is not liking the key frames of the HDV mov codec ? Or Maybe it has trouble dealing with the pixel aspect ratio ?
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Ericbowen replied 13 years, 2 months ago 2 Members · 1 Reply
