Activity › Forums › Apple Final Cut Pro › Exporting Issue
Exporting Issue
Posted by Jay Craig on May 14, 2013 at 8:41 pmSo I finished editing my project, tried to upload it but I get that damn “still referencing media on camera” pop up. So I used the “Reimporting from Camera/Archive” feature but still couldn’t export. Then I tried to transcode the media to create Create optimized media but still couldn’t export. I trashed my rendered files., still couldn’t export. I’m out of options.
Any advice?
Bill Davis replied 13 years, 4 months ago 3 Members · 5 Replies -
John Davidson
May 14, 2013 at 9:16 pmCan you export at all?
John Davidson | President / Creative Director | Magic Feather Inc.
Bill Davis
May 14, 2013 at 11:13 pmI faced this on some of the footage I brought back from NAB. Particularly one of the longer interviews I did from the show floor.
Eventually I noticed that the project I was working on was a long compound clip where I’d married the double system audio from my H4n to a video clip that I’d shot on my DSLR. But in reviewing the clip, I noticed that the compound had 3 minutes of video attached to about 5 minutes of audio where I’d let the H4n run after I shut off the DSLR shot.
I don’t think that caused the problem because I’ve done that before without issue – but somehow – and I don’t have a clue about whether it was the original video file, or the audio file, or the compound that I created from them – a corrupt “end of file” marker got created so that X trying to process the clip resulted in an internal failure.
Essentially, the clip would import – I could range it, tag it, edit with it, – but every time I tried to Share any project that contained that clip, X would NOT see it as a complete project and my Share options would be greyed out for that Project.
The solution was to go back to the BAD clip and export a new RANGE (with a good END marker) and reimport and replace the damaged clip with that.
Anyway, that solved the problem for me.
I was lucky because with just a few master clips, identifying the corrupt one was pretty easy. If you’ve got a bad clip among a lot of others, you may need to do the traditional problem finding process of copying and deleting the first half – then the last half of your timeline to narrow down where the problem is. And work that way to ID what’s bad.
It’s also possible that what I experienced (greyed share menu) can also be caused by other incomplete links to clips – so it may be something like unfinished calculations or other problems different from my “bad clip” but that’s how it worked out for me.
But that’s what I finally figured out as a cure.
Good luck.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Jay Craig
May 15, 2013 at 4:29 amI started working. I had to re-import the media files again.
I’m not sure why it did that but thx
Bill Davis
May 15, 2013 at 5:53 amIt *might* have simply been that X was processing stuff behind the scenes and wan’t done.
Often with X, patience and allowing the software to calculate in peace for a while will solve issues.
Honestly, some times I just go have lunch or knock off until the next day leaving my system open to process and render – and when I come back, stuff that wasn’t working before IS working.
As I’ve often noted, just because X does a LOT of stuff instantly, doesn’t mean it’s ready to do everything instantly.
FWIW.
