Activity Forums Maxon Cinema 4D Exporting into HDV
  • Exporting into HDV
    Posted by Randy Johnson on June 13, 2006 at 10:02 am
    I am not very experianced in Cinema.
    I have made a few detailed models with animated camera movement that I want to use in an HDV project…but the only HDV option I can find is 1080*60i and my project is 50i
    What is the highest quality option for me? (the final movie will be projected)
    thanks
    randy
    Randy Johnson replied 20 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    June 13, 2006 at 3:02 pm
    The presets are just that–you can enter whatever parameters you want in the pixel dimension and framerate fields. As I understand it, 50i is 1920 x 1080 @ 25 interlaced fps. So, just enter those parameters in the appropriate fields if you intend to render interlaced. Double the frame rate if you’re going to interlace in your compositing or editing application (recommended).
  • Randy Johnson
    June 21, 2006 at 12:29 pm
    That works very smoothly. Thanks.
