Activity › Forums › Apple Final Cut Pro Legacy › Exporting Individual Audio Tracks to seperate AIFF files using in/out points
  • Exporting Individual Audio Tracks to seperate AIFF files using in/out points
    Posted by Nikhil Kamkolkar on November 20, 2006 at 2:17 pm
    I have a feature film with the several Dolby 5.1 audio tracks imported and synced up.
    I now need to export the audio tracks (the portion within the in/out points set) in such a way that each audio track goes to a seperate aiff file.
    I can only seem to export as a stereo mix — and am unsure if I just turn off all the tracks except the one I want, whether it’s really exporting just the single track or a mix of all the tracks.
    Nikhil
    Nikhil Kamkolkar replied 19 years, 8 months ago 1 Member · 1 Reply
  • Nikhil Kamkolkar
    February 7, 2007 at 4:01 am
    In case anyone else runs into this —
    Ensure only one track is turned on at a time.
    Use Export -> Using Quicktime Conversion, then select AIFF and in options select MONO
