Activity Forums Apple Final Cut Pro Legacy Exporting in HD
  • Exporting in HD
    Posted by Ana Álvarez on March 16, 2013 at 4:22 pm
    Hello,
    First of all, I’m sorry for my spelling, English is not my first language.
    I’m quite new in the editing world, and when you read my message you’ll realize how true is that.
    So I’m trying to export a video. To capture the images I used a Canon 60D and I’ve been working on files that I converted to apple pro res 422, 25 fps.
    At first I used (and now I know it was quite absurd) the pro res codec and I ended up with a 12 gb file. Good quality of image but impossible to upload anywhere.
    After trying the apple pro res I used H.264 and I ended up with a 300 or so mb but I don’t really know how to configurate so it gets the best quality of image and I’m not sure if there’s any other way I could do it and get a better quality.
    I use Final Cut Pro 7.0.3. I also have compressor (but I cannot figure out how to really make it work well)
    If any of you knows how to get the best quality (or use compressor to reduce a 12 gb file to less than 2gb without losing a lot of quality) it would be very much appreciated.
    Thank you very much,
    Ana
    Ryan Holmes replied 13 years, 6 months ago 3 Members · 2 Replies
  • Rafael Amador
    March 16, 2013 at 6:21 pm
    Hi Ana,
    As you can imagine, the higher the data rate, the better the quality you can keep, but beside setting the data rate, there are two things you must do:
    – Make Multipass compression.
    – Set always Key-frames: AUTO.
    About he data rate (I guess you are working with 1920×1080 stuff) I think that from 15Mbps (15.000 Kbps) up you get a decent quality. With 35/40Mbps you will get Blu-ray like quality.
    rafael
  • Ryan Holmes
    March 16, 2013 at 7:46 pm
    Vimeo has a good compression help section. Select the program you want to export from on their website and they will walk you through the settings. Their settings work for pretty much any video sharing website….it’s probably the easiest place to start.
    https://vimeo.com/help/compression
    Ryan Holmes
    http://www.ryanholmes.me
    vimeo.com/ryanholmes
