Activity Forums Apple Final Cut Pro Legacy exporting in final cut 7.0.1 stretches all my text vertically
  • exporting in final cut 7.0.1 stretches all my text vertically
    Posted by Daniel Bellury on November 18, 2009 at 7:08 pm
    working in HD sequences (usually HDV 1080i30) when i export using compressor (usually the new “share” feature), my text gets stretched vertically. it happens with both regular text and with boris title 3d.
    any ideas?
    thanks,
    daniel
    David Heidelberger replied 16 years, 9 months ago 2 Members · 1 Reply
  • David Heidelberger
    November 18, 2009 at 8:16 pm
    You’re absolutely right. I believe this will only happen if you’re working in HD, and only with non-square pixels (HDV, DVCPRO-HD). And only if you’re scaling it to a size smaller than the actual width of your sequence. So, for example, with HDV, your sequence settings are 1440×1080. If your final output in Compressor is anything smaller than 1440×810 (which is a square pixel, 16:9 size), you’ll get this stretching. Furthermore, it’s not just text or Title 3D text. It will be any generator. Believe it or not, this has been a bug since at least Final Cut 6.0 and they still haven’t fixed it.
    You have two solutions. You can move your footage into a square pixel sequence (the ProRes 422 (HQ) 1920×1080 60i 48kHz preset, for example) and send that to Compressor. Be sure to check everything first and make sure Final Cut hasn’t distorted anything in a weird way.
    The only other solution (and probably easier) is to export a Quicktime movie and bring it into Compressor.
    Finally, if this annoys you enough, you should send Apple feedback.
    Even more effective, I think, you can register for a free Apple Developer Connection membership and use their bug-reporting tool. I have nothing to base this on, but I think they pay more attention to these official bug reports than they do to user feedback.
    Good luck,
    – David
