Activity Forums Apple Final Cut Pro Legacy Exporting in FCP 7
  • Exporting in FCP 7
    Posted by Lisa Gilbert on November 9, 2009 at 5:31 pm
    Using Final Cut Pro 7, when I export “a quicktime movie” or export “using quicktime conversion,” (even when I custom set the size of the movie file) quicktime reads the file this way:
    Format: 720×486
    Normal Size: 655×486
    Current Size: 655×486
    When I re-import the file into FCP, everything seems to be fine, however, I don’t understand why quicktime is displaying the movie at 655×486. My only guess is that Quicktime (7.6.4), is trying to compensate for the square/nonsquare pixels issue.
    Oddly, however, once I have the movie file opened in Quicktime, I can then export it from Quicktime and make a file that reads:
    Format: 720×486
    Normal Size: 720×486
    Current Size: 720×486
    What is happening here? I have not had this problem in previous versions of Final Cut.
    Alex Barreto replied 16 years, 2 months ago 2 Members · 1 Reply
  • Alex Barreto
    July 7, 2010 at 10:41 pm
    We were having this same issue. Very frustrating until we found the fix – which is really simple. Once you export your clip from the timeline, open the resulting .mov file in Quicktime Pro. Open the Movie Properties window. Under the Presentation tab, un-check the “Conform aperture to” check mark. Your movie should change size to 720×486. Make sure and save the file and you should be set.
    Alex Barreto
    Vapor Post
