Activity Forums Adobe After Effects exporting in AE for Avid 2020.8 with alpha
  • exporting in AE for Avid 2020.8 with alpha
    Posted by Lauryn Lukin on September 29, 2020 at 5:57 pm
    Hi, in the past i have always exported my AE with alpha graphics as an h264 .mov file for Avid. In the latest AE, there is no H264 option and any .mov file i export, says it can’t be imported into Avid. Any suggestions for how to export in AE so Avid 2020.8 can import it with an alpha?
    Brendon Murphy replied 5 years, 11 months ago 2 Members · 1 Reply
  • Brendon Murphy
    September 29, 2020 at 6:12 pm
    You can still export as h.264 through media encoder (I recommend mp4 instead of mov). However, H.264 is a highly compressed format with a GOP frame structure – definitely not recommended for editing or applications with alpha. If your projects are higher than 8 bpc, go with something like a TIFF or exr sequence. If you’re working at 8bpc, a png or tiff sequence should do. Make sure to enable the alpha channel in export settings.
