Activity › Forums › Boris FX Particle Illusion › exporting hi res images from particle illusion
  • Alan Lorence
    June 20, 2007 at 2:38 pm
    Yes, but if you’re on a Mac, you may be limited to 2048 x 2048 pixels.
    Just create the stage size you want in the project settings, then you’ll have to work zoomed out in particleIllusion. When you’re ready to render, save your project and use pIllusionRender to render it.
    Alan.
    http://www.wondertouch.com
