Activity Forums Apple Final Cut Pro Legacy Exporting HDV to wmv losing sync
  • Exporting HDV to wmv losing sync
    Posted by Jack Creswick on July 31, 2008 at 1:27 am
    G’day there,
    I have been having trouble exporting from an FCP HDV sequence to wmv through Flip4Mac. (Sorry about the alphabet soup)
    Never used to have trouble when I was using Blackmagic DV50 codec but ever since HDV became my “format of choice” have had this problem. Please note there isn’t a problem exporting through compressor to create DVDs. I did use a workaround for a while – export QT or AVI then do a conversion – but I’m now having sync trouble with that process.
    I went through the F4M people some time ago and sent many sample files but never had a consistent solution.
    Most of the clips I’m exporting are only about 1 – 2 minutes and I’m using basic settings of CBR 300, 320×180 although in the current (now overdue) project I want to make big files that will play back from PC laptops in high resolution.
    Equipment-wise I’m on a G5 2Gb dual processor with max RAM.
    Any help/advice will be much appreciated.
    Jack
    be.com.au
    Dale Larsen replied 18 years, 1 month ago 2 Members · 1 Reply
  • Dale Larsen
    August 6, 2008 at 11:25 pm
    Do you have a flip4mac license?
    I do it all the time from my timeline, in HD.
    I would also beef up your settings, if you want your product to be quality.
    Bigger frame size, 640×480 at least.
    higher data rate. 1k minimum.
    Dale
