Activity Forums Apple Final Cut Pro Legacy Exporting HD titles out of Motion
  • Exporting HD titles out of Motion
    Posted by Scott Sniffen on June 17, 2008 at 5:49 pm
    I have an XDCAM HD project in Motion for lower 3rds. When I export, the title ends up small in the lower part of the QT exported file. I have the setting set for the XDCAM HD codec. Any ideas why I get the small graphic?
    Scott Sniffen
    Scott Sniffen replied 18 years, 2 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    June 17, 2008 at 8:55 pm
    Are the Motion Project file settings also set to XDCAM? If not exporting to XDCam could result in making the file smaller… The project properties in Motion also have to be XDCAM to get WYSIWYG..
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Scott Sniffen
    June 17, 2008 at 9:24 pm
    It was simply that I had the view/zoom set at 100% and was fitting the title to the size on screen. Easy fix. But I did realize I can’t use the XDCAM HD codec when exporting a file with an alpha. FCP does not recognize the alpha. Used the lossless alpha movie. Seems to work.
    Scott
  • Scott Sniffen
    June 17, 2008 at 9:34 pm
    Not so fast. Just tried editing the lossless QT clips into the XDCAM HD timeline and I get an error: “Insufficient Content for Edit”. What is that? I tested this on a test project and it worked. What went wrong?
    Scott
