Activity › Forums › Maxon Cinema 4D › Exporting Hair as an Obj for Element in Cinema 4D
  • Exporting Hair as an Obj for Element in Cinema 4D
    Posted by Jay Blanda on January 14, 2019 at 5:50 pm
    This is driving me cray! I’ve scoured the inter webs for a week trying to flatten this speed bump but to no avail. So…
    I desperately need at least one swatch of fur or hair for a model I’m animating in Video Copilot’s Element 3D plug in, which means the hair must be exported as an obj. I know this means the hair must be converted into polygons but, with my rudimentary knowledge in Cinema 4D for hair, I cannot for the life of me figure it out.
    I found one or two “solutions” on various forums that are closed and far too vague. Whenever I followed the simplistic suggestions to make the hair editable, the hair would simply disappear and when I export as an Obj, again, the hair disappears.
    Again, I’ve already created beautiful fur, now I just have to somehow make it an Obj to import into Element 3D. Is this possible and does anyone have anymore of a comprehensive, effective suggestion to accomplish this?
    So much appreciation to the person who may be able to solve this and, of course, anyone even willing to try.
    Foday Justice Kamara replied 4 years, 6 months ago 5 Members · 5 Replies
  • Emir Bojorquez
    January 14, 2019 at 10:26 pm
    You could
    1.- Select the Hair >>>> Generate >>>> and select one option frome the dropdown menu (like flat)
    2.- Make it Editable and export
    Hope that helps, good luck
    Imagination is the best tool…
  • Jay Blanda
    January 27, 2019 at 12:50 am
    Emir, you are amazing! This worked perfectly! Thank you so much for taking your time to help me and include that tut gif, sooo helpful.
    JB
  • John Balazs
    October 7, 2019 at 7:02 am
    Im in the same position. Did you ever find a solution for this?
  • Emir Bojorquez
    October 7, 2019 at 4:03 pm
    You need to convert the hair to polygons, Element 3D does not have a hair support
    Take a look at the answer, it has a Gift showing you the steps
    Good Luck
  • Foday Justice Kamara
    March 24, 2022 at 3:57 pm
    The problem now is how to texture it with the same texture it has in Cinema 4D. Who can help with that?
