exporting from QT to WMV9 with specific bit rates
I have two inserts – an 18 min and a 50 minute insert. I need to export to WMV9 but with very specific requirements. The source is FCP 1920x1080i(xdcam ex1) – the final file must be 384×288 (so this needs to be letterboxed), a Video Bit rate of 340k and audio at 32k but maximum Bit Total Bit rate cannot exceed 400k. When I use the video and audio settings either directly from FCP (Compressor), or even exporting to a QT as 384×288 (letterboxed) and then using QT to export to WMV (I have Flip4mac), I get a total bit rate way above whats required. I’ve even put the small QT file through Squeeze and still the total bit rate is way over
I am missing something here? Any suggestions?
