Activity › Forums › Adobe Premiere Pro › Exporting from HD to mpeg2 problems
Posted by Henning Ravndal on May 28, 2010 at 10:40 pmWhen I try to export from .mts files 1440×1080 25fps to Mpeg2-DVD Pal high quality, the finished files have just half the length of the original film. It plays at doble the speed. I’m not an expert so the obvious answer is probably right. 😉
Ann Bens replied 16 years, 3 months ago 2 Members · 13 Replies -
Henning Ravndal
May 29, 2010 at 8:23 amI think im doing that. Before I start exporting it says estimatet size 580MB, but the finished file is just 340MB and plays at doble the speed.
Ann Bens
May 29, 2010 at 10:28 amCan you post your sequence settings and export settings.
Prefably a screendump. -
Henning Ravndal
May 29, 2010 at 12:13 pmJust tried to export to Mpeg2 (not the mpeg2-DVD) and PAL DV High Quality, and it worked without problems. I dont understand. 😛
Ann Bens
May 29, 2010 at 1:57 pmIn your export settings field order should be Upper and Aspect Ratio set to Widescreen.
I cannot read the sequence settings very clearly, what camera is used? Interlaced or progressive? -
Ann Bens
May 30, 2010 at 11:01 amI that case your project settings need to be corrected:
AVCHD 1080i25, and if you shot in CineMode the settings should be 1080p25
