Activity › Forums › Apple Final Cut Pro Legacy › Exporting from Final cut pro 7 to Betacam SP
  • Exporting from Final cut pro 7 to Betacam SP
    Posted by Rajiv Bopearatchy on February 15, 2012 at 12:14 pm
    Hello Everyone,
    I just bought an apple Imac and got Final cut pro 7 installed. I am new to both Apple and Final cut pro. Can some one please tell me after i’ve completed a project how can i transfer the project to a Betacam SP and what firewire cable should I use? Please help me out here.
    Thank you in advance.
    Raj
    Rajiv Bopearatchy replied 14 years, 7 months ago 3 Members · 4 Replies
  • Chris Tompkins
    February 15, 2012 at 6:26 pm
    You need an i/o card to lay out to tape.
    You are very limited in this area with an iMac.
    You need Firwire to Analog i/o such as the outdated AJA IOLA
    Also look @ Matrox products.
    Chris Tompkins
    Video Atlanta LLC
  • Dennis Leppell
    February 15, 2012 at 9:33 pm
    If you pass the video signal thru a dv deck, you do not need to lay off with i/o device. The trick though is deck control. We use a usb to rs422 converter/keyspan to control our beta deck.
  • Rajiv Bopearatchy
    February 17, 2012 at 5:20 am
    Thank you dennis. Appreciate your help Very much.
  • Rajiv Bopearatchy
    February 17, 2012 at 5:35 am
    Thank you Chris. Good tip. i will look in to both of the options.
