Activity Forums Apple Final Cut Pro Legacy Exporting from Final Cut
  • Shane Ross
    June 19, 2012 at 10:42 pm
    You need to export two discreet channels of audio…mono. I have a tutorial on how to do this:
    https://library.creativecow.net/ross_shane/multi-audio/1
    Shane
    Little Frog Post
  • Raul Ruiz
    June 20, 2012 at 2:17 am
    Hi there
    thanks for the reply, it was very very very helpful
    now
    i have this
    https://i744.photobucket.com/albums/xx86/sherdow15/Untitled-1.jpg
    there are any other program to export this compression? without the “Apple” compression
    and flexible to export multiple channels in Big endian
    thank you so much
  • Shane Ross
    June 20, 2012 at 6:59 am
    I wouldn’t worry about the APPLE in the name. I don’t think that matters. Not sure about the “little endian” thing. I think most people who have this deliverable use Episode to encode.
    Shane
    Little Frog Post
  • Raul Ruiz
    June 20, 2012 at 7:07 am
    i can’t export two “Big Endians” channels
    FC only let me export two channels of “Little Endians”
    where can i change this spec?
  • Rafael Amador
    June 20, 2012 at 1:19 pm
    If you are exporting with QT Conversion, in the Audio settings uncheck “Little Endian”.
    rafael
    http://www.nagavideo.com
  • Raul Ruiz
    June 20, 2012 at 10:31 pm
    Thank you very much for all your help
    im now trying with “Episode”
