Activity Forums Apple Final Cut Pro Exporting from FCP X-Audio compression
  • Exporting from FCP X-Audio compression
    Posted by John Anderson on June 10, 2015 at 4:20 pm
    Hello – new to FCP X (and video editing to begin with).
    I was wondering if anyone might know:
    1) Does ‘share’, export file accomplish lossless audio compression? (default setting seems to be Video Codec – Apple ProRes422 and Audio file format doesn’t seem modifiable but set at Quicktime Movie (Linear PCM) and the result is a .mov file.
    2) For my application, I’m not concerned at all with how large the resulting file is nor do I necessarily need it in .mov format – as long as I can play it on a Mac and somehow on a pc (VLC?). I just need to ensure that the audio portion does not get compressed at all.
    thank you kindly in advance for any suggestions to this newbie.
    -John
    Jeremy Garchow replied 11 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    June 10, 2015 at 6:12 pm
    You make audio settings in the share menu.
    You have choice of wav or aiff for uncompressed.
