Activity › Forums › Apple Final Cut Pro Legacy › Exporting from FCP to specification: ITU-R BT.709-5
  • Exporting from FCP to specification: ITU-R BT.709-5
    Posted by Andrew White on July 11, 2011 at 2:42 pm
    I have two series cut on FCP-7.03. I have been asked to deliver to a HD channel with the HDTV spec ITU-R BT.709-5. What codec should I use? Does Prores 4.2HQ meet these standards?
    Andrew White replied 15 years, 2 months ago 2 Members · 3 Replies
  • Rafael Amador
    July 11, 2011 at 9:14 pm
    “ITU-R BT.709-5” is the HD broadcast standard, as the “CCIR.601″ is the SD.
    Export to Prores and keep the signal ‘Broadcast Legal”.
    To avoid future problems with your clients:
    – Apply the “Broadcast Safe” with a “Very Conservative” or “Extremely Conservative”.
    – Apply the “RGB Limit” filter to avoid illegal RGB values.
    – Apply the “Proc Amp” filter to clip the under-Blacks.
    Or you can pass your movie through Color (set at 32bFP) with the Broadcast Safe filter ON.
    rafael
    http://www.nagavideo.com
  • Andrew White
    July 15, 2011 at 12:34 pm
    Thank you. This helps. But I don’t see any options for “Broadcast Safe” “RGB Limit” or “Proc Amp” in any of the export settings in FCP, or am I missing something?
  • Andrew White
    July 18, 2011 at 4:09 pm
    Thanks… I’ve figured it out.
    Andrew
