Activity Forums Apple Final Cut Pro Legacy Exporting from FC/Compressor Problem
  • Exporting from FC/Compressor Problem
    Posted by David Chabashvili on February 26, 2009 at 7:19 am
    Hi guys,
    I need an advice on exporting from Final Cut or Compressor.
    When I export from Final Cut with Compressor in DVD settings as the result I get the same picture (colors, contrast, etc.) as I see it in Final Cut’s Canvas. But when I export the file from Final Cut or Compressor in .MOV settings (ProRes, H.264, etc.) I get much brighter picture as the result.
    Is this normal? Should I tweak brightness or contrast in export menu?
    Thank you in advance.
    Henk Ekermans replied 17 years, 6 months ago 2 Members · 1 Reply
  • Henk Ekermans
    March 2, 2009 at 8:10 pm
    I am trying to export my sequences from FCP using compressor (something I have done plenty of times!). I am using the Best Quality 90 minutes settings, but when I submit my request, Compressor just hangs. Nothing happens in the progress bar and it says “Unknown time remaining”….
    What could be the problem?
