Activity › Forums › Maxon Cinema 4D › Exporting from C4D to Broadcast
  • Exporting from C4D to Broadcast
    Posted by Carlos Lopez on December 10, 2009 at 5:25 pm
    I have had issues setting up my renders to broadcast.
    Circulars objects seem right on a computer monitor but when I import them into flame and viewed in a broadcast monitor they seem stretch. I know the difference between square and rectangular pixels, how ever, I dont know how to set up my render settings… to make it right for broadcast.
    PLEASE HELP
    thanks!
    Carlos Lopez replied 16 years, 9 months ago 2 Members · 4 Replies
  • Tim Shetz
    December 10, 2009 at 7:08 pm
    It depends on what format you need to output to. Would it be NTSC or PAL? Are you outputting for HD?
    If you are outputting to NTSC or PAL you should pick one of the output presets that DON’T say square pixels such as NTSC D1 or NTSC d1 Widescreen not NTSC D1 Widescreen Square Pixel.
  • Carlos Lopez
    December 10, 2009 at 7:55 pm
    I outputting to 4:3 NTSC
    I uploaded a snap shot of my render settings…. if you cant see it here it is again…
    I used these setting following someone elses advise, but the frame is 450 not 486
    These aare the setting that i ussually use (see attached)
  • Tim Shetz
    December 10, 2009 at 8:03 pm
    Yea, in the first image it says your pixel aspect ratio is 1:1 which is square pixel for computer monitors.
    The second one looks correct as it is not square at 1:0.9
  • Carlos Lopez
    December 10, 2009 at 8:10 pm
    OK. thank you for your advise.. i will render a frame and let you know the outcome…
    cheers
