Activity Forums Adobe After Effects Exporting from After Effects to Avid MC5
  • Exporting from After Effects to Avid MC5
    Posted by Jack Wormell on November 11, 2011 at 7:29 pm
    Hi There
    I’m doing some end credits in After Effects which I then want to put into Avid Media Composer 5 with project settings: DNxHD 185, Rec709 colour space, 1080×1920 Progressive.
    I’m unsure as to what format the current After Effects project is in (I’m not the one actual doing the credits) but I was wondering if I can just make sure that on the export from After Effects the settings are the same as the Avid Project.
    Will this tackle any format problems, or does the After Effects project have to have the correct settings (the same as the Avid project) from the start?
    Cheers Guys
    Jack
    Jack Wormell replied 14 years, 10 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    November 11, 2011 at 7:59 pm
    Composition settings in AE are independent of the output/rendered file. This is quite dissimilar to NLEs that require a default format and CODECs when creating a timeline/sequence. However,
    However, having a default format and CODEC will actually allow the render engine to work more efficiently during previews.
    You should download the DNxHD CODEC from the Avid Website and install it onto your machine. Then render out to this CODEC.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Jack Wormell
    November 12, 2011 at 11:56 am
    Cheers Roland,
    Yeah, I thought the best thing would be to download the Avid Codec and export to that.
    Thanks for the help
    Jack
