Activity › Forums › Apple Final Cut Pro Legacy › Exporting for web with QT conversion
  • Exporting for web with QT conversion
    Posted by Krista Roessingh on December 7, 2009 at 6:26 pm
    Hi there,
    I’m editing and posting footage from several different cameras with different resolutions. The most troublesome produces .avis with divX codec, 570 TV lines WIDE. If I export with QT conversion using MPEG4 and broadband high settings for a 2min sequence, I get a blurry 18MB file. If I export with plain old QT, I get a 3.6 GB file. Either way the export and rendering take at least half an hour each. What I’d like of course is to maintain the original quality and enable streaming.
    With HD footage (from Sony XDCam or Canon VIXIA HG21) I have the same problem; I don’t know how to control the output file size to maintain highest res possible.
    Thanks in advance.
    Krista Roessingh replied 16 years, 10 months ago 2 Members · 2 Replies
  • Roli Rivelino
    December 8, 2009 at 11:18 am
    Try exporting your sequence to compressor and using the web settings, I would use the H.264 800kps streaming setting, you can also mess around with the settings and hit save and it will become one of your custom settings, which you can use again; don’t forget to rename.
    Don’t forget that Final Cut, down converts your footage to the lowest res you’re using, so if you have xdcam, hdv and dv, then FCP will down convert everything to dv, so that’s the quality you’ll be working with.
    good luck.
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
  • Krista Roessingh
    December 8, 2009 at 6:29 pm
    Thanks, I will try. Just to clarify, I am not mixing footage of different resolutions in my sequences, so the settings for each one are appropriate for the original res.
