Activity Forums Adobe Premiere Pro Exporting for Telestream Episode
  • Exporting for Telestream Episode
    Posted by Jeff Breuer on January 20, 2014 at 10:39 pm
    I made the FCP to PP switch a while back, but one part of my workflow I still have not translated well is my export settings for encoding. In FCP I would have sent my ProRes files out matching my sequence settings, take that file into Episode and encode it. But now I skip ProRes and just edit my raw files in Premiere (AVCHD – MPEG-4, AVC/H.264) but I’m not sure what to export so I keep it “lossless” before going into Episode Pro.
    I have tried “Match Sequence Settings” but it outputs an MPEG file that Episode won’t read. So usually I will just send out an H.264 file and send that to the encoder. Is that my best option to use until the rumored Episode Plugin comes out, or is there a better way? Thanks.
    Jeff
    Jeff Breuer replied 12 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Chris Borjis
    January 21, 2014 at 12:05 am
    I export from Premiere as Pro Res, just as I did before with FCP.
  • Jeff Breuer
    January 21, 2014 at 2:02 pm
    Do you edit in ProRes as well?
  • Morten
    January 21, 2014 at 2:57 pm
    Match sequence setting exports in the format you have chosen for your sequence preview renders. You can setup Prores as the main format for a sequence if you do a loot of preview renders, this will allow you to export including reuse of the rendered parts. Prores is a great Master format if you choose to go to Episode.
    – No Parking Production –
    Adobe CC, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8…. and FCPX on trial
  • Chris Borjis
    January 21, 2014 at 6:26 pm
    [Jeff Breuer] “Do you edit in ProRes as well?”
    no, just camera native files.
  • Jeff Breuer
    January 21, 2014 at 8:56 pm
    OK, so just edit my AVCHD native files in a ProRes sequence and then do a “Match Settings” export for Episode. I was concerned about creating more generation loss by doing that, but now that I think of it, that wouldn’t be any worse than when I would re-wrap my files into ProRes for edit in FCP.
  • Chris Borjis
    January 22, 2014 at 1:31 am
    no, edit avchd in an avchd sequence. (much smoother, quicker that way as quicktime is 32bit only)
    when your all done, export as a prores file.
  • Jeff Breuer
    January 22, 2014 at 2:30 pm
    OK. A little slow, got it now. Thanks for your help!
    Jeff
