Activity › Forums › Apple Final Cut Pro Legacy › Exporting for Premiere
Posted by Andrew Gregg on June 23, 2008 at 2:56 amI’m just wondering what settings I should use to export for premiere. I’ve tried the AVI setting under quicktime conversion, but it distorts the image. Is there any other setting I could use?
Thanks for any help.
Andrew Gregg replied 18 years, 2 months ago 4 Members · 13 Replies -
Andrew Gregg
June 23, 2008 at 6:44 amHi,
It was originally ingested using the HDCAM EX 1 format. I then moved it to a normal DV timeline in order to crop the size from 16:9 to 4:3.
Cheers.
Andrew Gregg
Director
LiveABC Taiwan -
Andy Mees
June 23, 2008 at 8:45 amand what is it you want to export to Premiere? the original (16:9) XDCAM EX source clips or the (4:3) DV downconvert?
Andrew Gregg
June 23, 2008 at 10:08 amThe downconvert. The project’s for a company that makes training video software, but it’s all in 4:3. I shot in 16:9. They also want consistent titles, so they want those done in premiere. What’s weird is that the footage is in 720*480 format, but it’s squeezed and changes to 640*480 when it goes into premiere. Is this a premiere issue?
Thanks.
Andrew Gregg
Director
LiveABC Taiwan -
Andy Mees
June 23, 2008 at 10:40 amhow is it when you open your converted AVI file back into FCP? what does it report for its format properties in the clip info (cmd-9)?
what steps are you taking to create the avi exactly? am assuming:
export > using quicktime conversion…
w/ format >avi >> options >> video settings >> compression type > DV/DVCPRO – NTSC -
Andrew Gregg
June 23, 2008 at 1:30 pmWhen I import back into final cut pro, it says the settings are 640*480. The image is stretched wide in my timeline, which is set to 720*480. In the premiere timeline (which is also set to 720*480), it’s also listed as 640*480, but the image is squeezed in. This is confusing.
I am using
w/ format >avi >> options >> video settings >> compression type > DV/DVCPRO – NTSCIn the final box, I’m selecting 4:3 for the aspect ratio. I suppose that this is the problem, since 640*480 is 4:3. Is there any way to export to 720×480? Or, is there any way to export MPEG-2 at 720*480?
Thanks again.
Andrew Gregg
Director
LiveABC Taiwan -
Andrew Gregg
June 23, 2008 at 1:33 pmThe problem is that I have some telephone conversations shot at DV 720×480 that need to be inter cut with this EX 1 footage. It needs to be at the same aspect ratio in order to cut together.
Andrew Gregg
Director
LiveABC Taiwan -
Tom Brooks
June 23, 2008 at 1:39 pmI haven’t used PRemiere Pro since version 6.0, but it’s a Quicktime compatible app, is it not? Can’t you set up your project to edit the Apple DV Quicktime files directly?
Andrew Gregg
June 23, 2008 at 3:52 pmIf it’s as simple as this I’m going to be kicking myself for a while. Last time I remembered, Premiere couldn’t really handle quicktime files. But that was 1.0. I’ll ask around on their forum, and try it out tomorrow at work.
Thanks.
Andrew Gregg
Director
LiveABC Taiwan -
Michael Hancock
June 23, 2008 at 4:25 pmI believe Premiere is avi based, but it can take a Quicktime. It will just have to render it to play in realtime.
Michael
