Activity Forums Adobe Premiere Pro Exporting for PAL
  • Exporting for PAL
    Posted by Megan Pollin on September 18, 2012 at 3:46 pm
    I have a project in Adobe Premiere (1080p24) and I need to export it so it’s compatible for broadcast in a PAL area.
    They’ve asked for PAL, MPEG2 but I’m just if there’s a preset that would work or if there’s more I need to do to make this work.
    Thanks for the help!
    Chris Tompkins replied 13 years, 11 months ago 2 Members · 1 Reply
  • Chris Tompkins
    September 18, 2012 at 10:40 pm
    The proper way would be to send off a tape master for a HD foreign conversion.
    But if you are only going to use what you have, try exporting to 1080/25p when making the mpeg file.
    I recently received a 108025p PAL clip. Converted it to 24p and it did the job. But you run the risk of speed change/pitch shift and lipsync issues, depending on what you’re working with.
    Chris Tompkins
    Video Atlanta LLC
