Activity › Forums › Apple Final Cut Pro Legacy › EXPORTING FOR BROADCAST (Music video)
  • EXPORTING FOR BROADCAST (Music video)
    Posted by Máté Bögi on September 24, 2012 at 9:45 am
    I have searched the internet for this problem but couldn’t find anywhere to get help. A television channel have asked me to export my edit in the following format:
    Format: DV 4:2:0 25 Mb/s
    Audio reference (RMS):-12 dBf
    Maximum audio: -6 dBf
    Chroma subsampling:4:2:2
    Format: DV PAL-25, self-contained (QuickTime Movie )
    Audio channels: Left, Right ( 48 kHz )
    I have edited in final cut for over 3 years now, but I have never had to export with these conditions. I have no idea how to set my quicktime conversion to 25 data rate and still have a DV export. How do I set chroma subsuming to 4:2:2? … And Final Cut doesn’t have a DV PAL -25 compression type, am I right?
    The edit is in FULL HD (1920×1080), compressed from RED RAW 4K. fps is: 23.98…
    Thank You
    Mate Boegi
    Rafael Amador replied 14 years ago 4 Members · 10 Replies
  • 10 Replies
  • Rafael Amador
    September 24, 2012 at 9:50 am
    Hi Mate,
    You are right, that request is completely contradictory.
    DV25 is 420. They can’t ask you DV25 and 422 at the same time.
    rafael
    http://www.nagavideo.com
  • Bouke Vahl
    September 24, 2012 at 11:36 am
    The 422 is indeed bogus, but the rest is pretty normal DV…
    And FCP has an easy setup for that…
    But before you’re there:
    since you shot 23.98, speed up to 25.
    since you shot HD, make a center cut or do a pan/scan…
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Shane Ross
    September 24, 2012 at 1:42 pm
    Oh the humanity. Shot Red 4K, deliver DV25.
    The frame rate issue will be the trickiest. If you conform 24 to 25, your timing changes and audio has a slight pitch shift. Can you deal with that?
    Shane
    Little Frog Post
  • Máté Bögi
    September 24, 2012 at 3:04 pm
    Well I don’t really have a different solution do I?
  • Máté Bögi
    September 24, 2012 at 3:07 pm
    Thanks, I’ll make a center cut, but still don’t really get the compression.. Should I just
    export:
    Compression type: DV – PAL?.. With easy setup do you mean: Final Cut pro – File – Easysetup?
  • Bouke Vahl
    September 24, 2012 at 3:32 pm
    Nope, make an inbetween @ 720 x 576 in 23.976,
    (Prores or whatever, as long as it is I frame only)
    Take that to Cinematools and conform to 25
    Then, speed up your sound while maintaining pitch (any decent audio editor can do this), then export the whole shebang to DV pal.
    (Using an easy setup in FCP, but other options are plenty)
    Bouke
  • Rafael Amador
    September 24, 2012 at 3:38 pm
    [Máté Bögi] “Compression type: DV – PAL?.. With easy setup do you mean: Final Cut pro – File – Easysetup?”
    Yes, DV PAL 48Kz is the sequence preset name. No Anamorphic.
    rafael
  • Máté Bögi
    September 24, 2012 at 3:44 pm
    Okay, thank you very much :).. I’ll try to speed up the audio.. And a last question:
    With “25 Mb/s” do they just mean 25fps? Have never run into Mb/s before, or is it Date Rate?
    Thank you!
  • Shane Ross
    September 24, 2012 at 6:29 pm
    I would not recommend doing any of this inside FCP. Work on your master, then EXPORT that as a self contained file. Full size file….or even 1080, at 23.98. Then conform that to 25fps. Bring the result into a Compressor to convert it to PAL DV. And the audio into Soundtrack Pro to adjust the pitch shift.
    Again, note that your timing between 24fps and 25fps will change, because you are using the same frames, only speeding things up by one frame every second.
    But that’s me. I haven’t delivered NTSC to PAL, so I might be wrong. Trust the other guys over me. But maybe this suggestion will give them ideas, or they can shoot me down and say “that’s wrong for SO MANY reasons, Shane.”
    Shane
    Little Frog Post
  • Rafael Amador
    September 25, 2012 at 2:09 am
    [Shane Ross] “I would not recommend doing any of this inside FCP. Work on your master, then EXPORT that as a self contained file. Full size file….or even 1080, at 23.98. Then conform that to 25fps. Bring the result into a Compressor to convert it to PAL DV. And the audio into Soundtrack Pro to adjust the pitch shift.
    Again, note that your timing between 24fps and 25fps will change, because you are using the same frames, only speeding things up by one frame every second. “
    Sure, i would do as you suggest for time-base correction and downscaling.
    i would care about the audio pitch only if there is some music or interviews. For normal ambience I would leave it as it is.
    rafael
