Activity Forums Apple Final Cut Pro Legacy Exporting for Big Screen playback
  • Exporting for Big Screen playback
    Posted by Maria-luisa Meredith on June 8, 2010 at 1:27 pm
    Hi
    I’ve created a title slide for an event (animated background with transparent photoshop text).
    At 100% in my canvas the text looks a little choppy but it’s ok on my external crt monitor.
    What is the best export setting to retain the highest quality possible when projected onto a 10ft screen?
    Maria
    Maria-luisa Meredith replied 16 years, 2 months ago 3 Members · 4 Replies
  • Rafael Amador
    June 8, 2010 at 2:39 pm
    The best quality will go with the less compressed master you can achieve.
    What you have to think about is which device you will use to play the movie.
    With a laptop and an external FW800 HD you will be able to play HD Prores.
    rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    June 8, 2010 at 3:22 pm
    There’s a lot that can go in to this.
    The first question, is what are you playing back from and is the projector HD or SD?
    Only then can you determine what your best master will be.
  • Maria-luisa Meredith
    June 9, 2010 at 7:42 am
    Hi and thanks for the response. Most likely this will be played from a DVD and then sent to screen via a pro-level projector.
    Maria
    June 10, 2010 at 12:00 pm
    Thanks, I’ll do that.
    M
