Activity › Forums › Apple Final Cut Pro Legacy › Exporting footage with colour solid masks.
  • Exporting footage with colour solid masks.
    Posted by Michael Coates on January 31, 2012 at 3:33 pm
    Hello once again, different question here, I have a clip 15 seconds in length that contained images in the background I didn’t want in. I was able to add a solid colour to these parts of the image and ‘mask’ them – essentially deleting them out.
    It looks fine but I’m curious now, can I export with the masks in place without losing quality to the overall image. If I just export as current settings will it be essentially the same file but with the ‘masking’ rendered on top?
    Thanks for reading
    Michael
    Michael Coates replied 14 years, 8 months ago 2 Members · 2 Replies
  • Rafael Amador
    January 31, 2012 at 5:08 pm
    [Michael Coates] “It looks fine but I’m curious now, can I export with the masks in place without losing quality to the overall image. If I just export as current settings will it be essentially the same file but with the ‘masking’ rendered on top?”
    The whole picture will be processed, but if you are using a good codec, the un-masked areas won’t degrades.
    If you export Uncompressed, you will keep the original pixel.
    rafael
    http://www.nagavideo.com
  • Michael Coates
    February 1, 2012 at 12:14 am
    Thank you very much, exported uncompressed with the colour masks and it looks the same to me without the annoying and intrusive objects which I covered up.
    Superb 🙂
