Activity Forums Adobe After Effects Exporting FLVs
  • Exporting FLVs
    Posted by Robert Hallion on March 20, 2008 at 6:18 pm
    Can someone explain how After Effects chooses which exporter to use for FLVs?
    I have 3 different scenarios and 3 different exporters are showing up in After Effects. I would prefer to use the Flash exporter since that one seems to give us the best results.
    In CS2 on my PC when I do export FLV the Flash exporter shows up.
    https://www.geniusdv.com/weblog/archives/After%20Effects%20and%20Flash%20settings-thumb.gif
    My co-worker just installed CS3 and when he does this option he gets the new Flash Exporter. But he can’t use it because it says for him to use the render Queue. When he uses the render Queue the Adobe Media Exporter is used.
    https://www.mediacollege.com/adobe/premiere/pro/export/images/vCS3_exportsettings-winmedia.gif
    We do not like the results that the Adobe Media Exporter gives even when using the same settings. I never liked using in Premiere because I always had bad results and it seemed to crash a lot.
    The last scenario is using CS3 on my MAC. When I do export FLV I am able to use the new Flash exporter. When going through the render queue I get the Adobe Media Exporter.
    The best option would be the render queue with the Flash Exporter.
    Can someone explain why there is not just one option? And why I can’t set which one I want to use. We do have the Flash exporter installed on all three machines. Any help would be great!
    Robert Hallion replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
