Activity › Forums › Apple Final Cut Pro › Exporting FCPX Project to DVCAM tape?
  • Exporting FCPX Project to DVCAM tape?
    Posted by Jack Niedenthal on July 4, 2012 at 3:13 am
    I need to export one of my projects onto a DVCAM tape for a film festival, can someone explain to me this process from FCPX?
    Do I export my project as a .mov media file first, then use this file to get it put on DVCAM? Or do I need to connect my computer to equipment that makes a DVCAM tape and export it directly onto a tape? Sorry, I know nothing about this, any help you could give would be appreciated.
    Jack Niedenthal
    Microwave Films of the Marshall Islands
    http://www.microwavefilms.org
    iMac i7 using Lion 10.7.x, HPX 170 using only one 64GB card
    I live on an island in the middle of the Pacific, YOU are my only resource.
    Jack Niedenthal replied 14 years, 2 months ago 4 Members · 4 Replies
  • Alban Egger
    July 4, 2012 at 6:05 am
    FCPX does not offer any print-to-tape functionality!
    You could try in iMovie. I think there is a tool for that.
    I always use an old Windows laptop with a firewire port. Windows moviemaker does it…….you just need to create a file in FCPX that can be read with Windows. Probably a MPEG program stream.
  • Eric Santiago
    July 4, 2012 at 11:37 am
    The only to do it is to put a file based system in between the mix.
    Basically dump the file onto a DVD or BD then play back to DVCAM.
    The other way is to use Blackmagics cheap Intensity PCI card or Shuttle/Extreme.
  • T. Payton
    July 4, 2012 at 5:02 pm
    Regarding the iMovie you need, it is iMovie HD 6. It used to be free from Apple but not anymore.
    As an alternative to making a DVD and then going DVD to DV, I would try to find someone in your area that has FCP 7, or Premier. You could give them a DV Quicktime and they can put it to tape.
    As an aside, DVCAM is pretty old technology. It’s only SD, and very odd that they would want that. I would go ahead and submit a DVD also to them.
    T. Payton
    OneCreative, Albuquerque
  • Jack Niedenthal
    July 4, 2012 at 8:57 pm
    What is DCP-NTSC and how would that work flow go from FCPX?
    Jack Niedenthal
