Exporting EDLs for Cue Sheets.
Does anyone know of an efficient automated function that would allow me to export an EDL from Avid that can be used to create a detailed Cue Sheet? Oftentimes inside my sequences I will have the same cue overlapping itself on two or more tracks. In these instances they need to be calculated as one use. Also, fade Ins and Outs need to be calculated into their timings.
As it is now, I am having to go through each sequence, marking the individual clips, document their durations, add them all up and then type it all out into a separate word document. Some times for up to 60 cues per sequence.
If there is an Application or Automated workflow that anyone knows of to streamline this process it would be a great help and time saver.My desired end result is a word document that lists each cue used in my sequence (in order of use) How many times its was used (overlapping counted as one use) and the total time it was used.
