Activity › Forums › Avid Media Composer › Exporting DVCProHD native file
  • Exporting DVCProHD native file
    Posted by Warren Baker on July 13, 2011 at 12:47 am
    Looking for the easiest way to export a DVCProHD file, say, a 20 minute video. Don’t want to export to a P2 card. Just want to export a file to a drive that can be easily imported into other editing applications. If not DVCProHD, I’m looking for a low bitrate HD file type that can be easily exported out of Avid and imported into other editing applications.
    Thanks in advance.
    Job Ter burg replied 15 years, 2 months ago 3 Members · 4 Replies
  • Shane Ross
    July 13, 2011 at 5:50 am
    DNxHD 115..or 145. Whatever is available for that format. The other computers just need to download the FREE Avid DNxHD codecs and they are good to go.
    Shane
  • Job Ter burg
    July 13, 2011 at 8:20 am
    Why not try Same-As-Source? Quickest export, no quality loss.
  • Warren Baker
    July 13, 2011 at 11:07 am
    Thanks for the suggestions.
    Same as source requires working in DVCProHD. So if you’re working in DNxHD, you’ll need to transcode before exporting. It’d be nice not to take that extra step.
  • Job Ter burg
    July 13, 2011 at 12:00 pm
    The topic made me assume you wanted to stay native. Hence same as source. If not, transcode to a middle-high flavor of DNxHD, then use same as source to export.
