Activity Forums Adobe After Effects Exporting DV Project – Vertical Lines
  • Exporting DV Project – Vertical Lines
    Posted by Joshua Moise on April 4, 2007 at 3:28 pm
    Hello all. I am exporting a 16:9 DV project from After Effects as a Quicktime(I tried both AvidDV & DV/NTSC codecs) and I keep getting these vertical lines on the final output. Is there any way to get rid of these?
    Here are the specs for the project:
    Exported Quicktime DV/NTSC 16:9 from Avid Xpress DV
    Exported from AE @ Avid DV at 16:9
    Kevin Camp replied 19 years, 5 months ago 2 Members · 4 Replies
  • Joshua Moise
    April 4, 2007 at 4:23 pm
    Thanks. I looked at the project at half resolution and it appears that the vertical lines are coming from the source clip which, as I said, was exported out of Avid Xpress DV as a quicktime (DV/NTSC, interlaced, 16:9). I’ll head to the Avid forum for further help.
    Thanks a lot.
  • Kevin Camp
    April 4, 2007 at 8:45 pm
    you might try exporting out of avid as a quicktime using the lossless animation codec… exporting to dv is recompressing the dv footage you edited. if the lines you are seeing are fairly subtle, they may be due to compression.
    just to ask… are you seeing these lines in a broadcast monitor or your computer screen, and are you only seeing these in ae, or do you also see them on the ae rendered footage when it comes back in to avid? i’m wondering if you’re seeing the pixel aspect correction in ae’s preview window, which would look sort of like vertical ‘aliasing skips’ in the image. in a broadcast monitor (with 16×9 setting) or back in avid it would look normal.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Joshua Moise
    April 4, 2007 at 9:21 pm
    Thanks for the reply. I’ll bring the file back into Avid and see what happens. I’m seeing the lines on the computer screen as I do not have a broadcast monitor. I saw the lines when I blew up the source quicktime file that I exported from Avid Xpress DV. I tried exporting it with the animation codec, but when I did so, the file looked blown out and didn’t have the same look as it did in Avid. A bit confusing indeed.
  • Kevin Camp
    April 4, 2007 at 9:29 pm
    the blown out look of the exported qt animation file may be due the yuv-rgb conversion (or lack of conversion)… when you export out of avid, i believe you should be able to select a conversion from 601 (yuv) to rgb… and, like wise, when you import back into avid there should be an option to convert from rgb source footage.
    Kevin Camp
