Activity Forums Apple Final Cut Pro Legacy Exporting Current Settings – Extra Compressed?
  • Exporting Current Settings – Extra Compressed?
    Posted by Nick Tempest on October 8, 2007 at 2:57 am
    Please forgive if this isn’t the right place for this. I also posted this question on the Kona forum because I’m using a Kona. Again sorry if that is a faux pas, just trying to make sure enough people see my question.
    My question:
    I want to make a master of a 720p project that is not compressed any more than it already was when shot to tape. We’re not sure what camera we’ll use but let’s assume for the sake of this post we’ll be shooting with a Varicam, to tape.
    Then we digitize everything with the DVCPRO HD Codec, through firewire.
    We edit in 720p, full resolution, etc.
    At the end of our edit we want to take a final master to a post-house for color correction.
    My question is: is it better/ easier to export a quicktime with ‘Current Settings’ and take an uncompressed DVCPRO HD movie to the color correction house? Or to hook up the Panasonic deck and make a DVCPRO HD master tape, and take that?
    Or to export an EDL and have the color correction house redigitize all the original tapes and rebuild the sequence.
    In other words, does exporting a movie add compression?
    Does making a tape add compression?
    Looking for a way to make a master to take to color correction shop that is not compressed any more than it already was as I was editing it.
    Thanks so much!
    Shane Ross replied 18 years, 11 months ago 2 Members · 1 Reply
  • Shane Ross
    October 8, 2007 at 3:34 am
    [Nick Tempest] “My question is: is it better/ easier to export a quicktime with ‘Current Settings’ and take an uncompressed DVCPRO HD movie to the color correction house? Or to hook up the Panasonic deck and make a DVCPRO HD master tape, and take that?”
    Either works. But I tend to export a QT Movie, self contained, using the sequence settings. And I edit DVCPRO HD from Varicam and HVX-200. I take this to a post facility for output to HDCAM.
    [Nick Tempest] “In other words, does exporting a movie add compression?”
    Nope…none at all.
    [Nick Tempest] “Does making a tape add compression?”
    Nope…none at all.
    [Nick Tempest] “Or to export an EDL and have the color correction house redigitize all the original tapes and rebuild the sequence.”
    No need. If you captured using the DVCPRO HD 720p Easy Setup, you are at full resolution.
    There are many options. Now what you need to do is contact the post facility that will be doing the final color correction and output and ask what they want.
    Shane
    Littlefrog Post
    http://www.lfhd.net
