Activity Forums Adobe After Effects Expressions Exporting comp with different texts
  • Exporting comp with different texts
    Posted by Jurjen Versteeg on June 9, 2009 at 12:45 pm
    Hello,
    I posted this message in the After Effects forum, but were advised to put it in the Expressions forum:
    I was wondering if there is any way to export a comp multiple times, but automatically with different texts in it.
    So let’s say I have a composition called “Fashion student” with a text layer and I want to export this composition, but in every export I want a different student name in it. Like using an array or something?
    Is there a script, preset or setting which can solve this?
    Thanks in advance,
    Jurjen
    Andy George replied 17 years, 3 months ago 2 Members · 3 Replies
  • Andy George
    June 9, 2009 at 7:59 pm
    Jurjen,
    Here is a script for automatic text replacement referencing
    a text file. I just used it for the first time the other day.
    Pretty slick.
    https://www.aenhancers.com/viewtopic.php?f=3&t=1083
    Andy
  • Jurjen Versteeg
    June 9, 2009 at 8:44 pm
    Wow! This works awesome! Thanks a lot.
    But I still need to put them manually in the Render Queue, right?
  • Andy George
    June 9, 2009 at 9:28 pm
    Yes you would. But if you set up your render settings for 1 comp you can drag and drop the rest
    of the new comps into the render Q and they should be good to go. So it should be a pretty quick operation.
    Andy
