Activity Forums Adobe Premiere Pro Exporting Clips
  • Exporting Clips
    Posted by Bodybuildingbs on August 4, 2005 at 2:43 am
    Once you have unlocked the audio and video portions of a clip is there anyway to just click on that clip and have the audio and video exported without trying to line up the work area each time?
    Thank you.
    I have tried holding the control and highlighting both the audio and video but when I try to export it always says audio disabled or video disabled depending on which I click first..
    Craig Howard replied 21 years, 1 month ago 3 Members · 2 Replies
  • Labrisher
    August 4, 2005 at 5:10 am
    Not sure I understand what you want done but to re-sync your audio and video, you need only Shift + click on each track, right click either track and “Link Audio and Video,” and you’ll see a small box telling you how much, if any, they’re out of sync. Then just right click on either of the boxes and you’ll see a command to “Move into sync.”
    Make sure you have room for the clips to move to bring them into sync. If this isn’t what you want, please post again.
  • Craig Howard
    August 5, 2005 at 2:29 am
    There is an option to export video , audio or both in the settings menu as well as an option to export Work area bar or Entire project. A combination of these things will do what you want. ( That is if I understood your question properly)
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
