Exporting clip from FCP 7 back to JVC HM 700 for playback thru camera
Hello,
Hope someone can help.
I am using an HM 700 with FCP 7. I would like to be able to drag my finished news story back to the SD card, and then playback thru the camera to LiveU via SDI.
This worked with my GY -200 as “print to video.”However, with the HM 700, when I put clips on the SD card, the Camera does not recognize them.
Camera only sees the clips that it shot.Is there an export setting out of FCP that will do the trick?
Thanks.
Tim
