Activity › Forums › Apple Final Cut Pro Legacy › exporting AVI out of FCP
  • exporting AVI out of FCP
    Posted by Christina Rule on May 20, 2009 at 12:48 am
    Hello!
    I have to deliver an AVI file and I was wondering the best way to do so. The File that is coming to me is coming from comp, they will be getting exr image seq. I usually have them deliver movs with a NONE codec. Should I have them deliver AVI to me?
    I guess this was a 2 part question…
    If they do deliver MOV to me what is the best way to convert them to AVI?
    Thank you in advance!
    http://www.christinarule.com
    Megan West replied 17 years, 3 months ago 4 Members · 10 Replies
  • 10 Replies
  • Jeremy Garchow
    May 20, 2009 at 2:14 am
    AVI is simply a wrapper that can be used to wrap any codec, just like QT. You need to find out exactly what it is that they need.
    No, don’t have anyone deliver you an AVI if you need to do further editing in FCP.
    Jeremy
  • Christina Rule
    May 20, 2009 at 2:27 am
    Hey Jeremy!
    All that they said was just Avi format. 30fps…I noticed when I was testing a few exports out of FC that I had the option of Cinepak,BMP,NONE and a few others… I know Cinepak has lower video quality but what about the others? Any recommendations ? I would like to keep Best quality possible
  • Jeremy Garchow
    May 20, 2009 at 2:34 am
    None will probably be best (and biggest).
  • Christina Rule
    May 20, 2009 at 4:01 am
    sweet thanks Ill let you know how it works out!
  • Rich Rubasch
    May 20, 2009 at 3:27 pm
    But using none will also limit you to the 2 gig file size limitation of AVI. So clips longer than about 4 minutes will only be a partial clip.
    MPEG Streamclip can create AVIs using many more compressors including QT compressors and embed them in the wrapper. But whoever opens them must have QT loaded on the machine.
    Rich Rubasch
    Tilt Media
  • Christina Rule
    May 20, 2009 at 3:30 pm
    Hey Rich,
    If I know that the clip will not be that long would you suggest using None? Or still Stream clip?
  • Jeremy Garchow
    May 20, 2009 at 3:59 pm
    Compressor can create AVIs as well, in dv, dv50, BMP, None or Cinepak.
    Jeremy
  • Christina Rule
    May 20, 2009 at 4:00 pm
    Is there any difference in rendering out of FCP or compressor?
  • Jeremy Garchow
    May 20, 2009 at 4:20 pm
    Compressor has better processing. I’d use Compressor.
  • Megan West
    July 2, 2009 at 4:04 pm
    Can you tell me how export from an FCP timeline using compressor to create an AVI?
