Activity Forums Adobe Premiere Pro exporting audio
  • exporting audio
    Posted by Aria Slade on March 16, 2006 at 10:43 pm
    whenever I export the timeline to a project with video and audio tracks, the audio always comes out with skips and flaws that weren’t there before… but when I try to change the settings, premiere shuts down. what am I doing wrong?
    Aria Slade replied 20 years, 6 months ago 3 Members · 5 Replies
  • Tony Bartolucci
    March 17, 2006 at 1:44 am
    What are your export settings from premiere?
  • Aria Slade
    March 17, 2006 at 3:08 am
    Audio Settings:
    Rate: 32000 Hz
    Format: 16 Bit-Stereo
    Compressor: Uncompressed
    Interleave: 1 Second
    Processing Options:
    Enhance Rate Conversion – Off
    (note: these are the default settings for the program, but they don’t work)
  • Tony Bartolucci
    March 17, 2006 at 3:32 pm
    just using wav
  • Andre Gagnon
    March 18, 2006 at 8:19 pm
    [Aria Slade] “whenever I export the timeline to a project with video and audio tracks, the audio always comes out with skips and flaws that weren’t there before… but when I try to change the settings, premiere shuts down. what am I doing wrong?”
    On the timeline, right click on your clip, Unlink the video and audio. Drag the audio to separate it physically fron the video clip, and hilite it. Go to the menu Clip-> Audio Options-> and hit Render & Replace. Premiere will quickly render it to a WaV clip. Then, use the options Export-> Audio in Premiere.
  • Aria Slade
    March 19, 2006 at 2:41 pm
    I have premiere 6.5 for mac, which doesn’t seem to have that command… I clicked the “render audio” command, but nothing happened, and there’s a separate command to replace clips, but not a “render and replace”.
