Activity Forums Adobe Premiere Pro exporting as dv-avi
  • exporting as dv-avi
    Posted by Sotan91 on November 8, 2006 at 11:33 pm
    I use Adobe Premiere Pro 1.5.1 to edit clips (source can be either DV or HDV)
    Do you lose picture quality when you export a clip as a Microsoft DV AVI (when the source is DV)?
    Also, is it the same with the Cineform HDV AVI (when the source is HDV)?
    Thank you for your response.
    Vince Becquiot replied 19 years, 10 months ago 2 Members · 1 Reply
  • Vince Becquiot
    November 9, 2006 at 1:53 am
    Yes if you add effects, no if you are only doing straight cuts.
    Vnce
