Activity Forums Adobe Premiere Pro Exporting and XML with Meta data fields
  • Exporting and XML with Meta data fields
    Posted by Will Fiennes on May 11, 2015 at 2:27 pm
    Wondering if anybody can help with this.
    We are doing an 8 x 43 mins docs series that looks like it may have about 5 % of Archive.
    During the offline stage we are ripping youtube clips and the like before tracking down and sorting out licenses etc.
    In order to keep track of Archive as we go we would like to input metadata into the following columns :
    Label, Publisher and Advisory.
    The idea was then to at rough cuts 1-4 we would export an XML with the desired metadata fields.
    The problem is we cannot get that data out of premier. Obviously I/O, sequence time, codec, audio format is fine but when reading the XML in Sequence Clip Reporter we can’t see and thus convert to a text file a doc that contains our required info.
    Any suggestions
    thanks
    Will
    Mac Pros
    Adobe Premier CC 2014
    Edit Assistant/Assistant Editor/Film maker
    Andrew Kimery replied 11 years, 4 months ago 3 Members · 3 Replies
  • James Strawn
    May 11, 2015 at 3:18 pm
    I’m not sure how you would go about converting the xml metadata into selective text file(s) that you can use standalone outside of PrPro and CS/CC. But perhaps Prelude could help here?
    If you ingest into Pl it will read the xml data you authored in PrPro, then you can do a rough cut there and add markers and other logging info before sending the whole thing back to PrPro for final editing. I know it seems like a somewhat circular workflow, but it’s the best I could think of at this time. Perhaps someone has a more straightforward solution though… let’s see.
    Software Quality Assurance – Digital Video at Adobe Systems
  • Will Fiennes
    May 11, 2015 at 10:05 pm
    Thanks for your reply James
    Hmm. It seems strange in this advancing world of metadata that we can not export that data in some sort of tangible format. We really just want a sequence report with all the extra data we have added so then our production team can go through the cut and start the process of licensing. Of course we could export an edl and bitc QuickTime but that does not help them find out the source…
    on we go
  • Andrew Kimery
    May 12, 2015 at 2:20 am
    If you haven’t done so already I’d contact Greg or Philip (the makers of Sequence Clip Reporter) and aks for their help/advice.
