Activity › Forums › Adobe Premiere Pro › exporting and sequence setting not matching up
  • exporting and sequence setting not matching up
    Posted by Krystle Patino-serrano on March 20, 2015 at 6:00 pm
    i use a canon 7d with 1920×1080 24fps for my settings when recording video. in order to speed things along i usually create a new sequence with a new clip so that i don’t have to worry about choosing a sequence setting and just letting adobe match my sequence settings to my footage.(also because there are so many options i don’t know which one to choose) But recently when i try to export it goes to the preset of NTSC DV 24p even though my sequence and video settings are 1920×1080 24. When i manually change the export setting to 1080i 25 which is the closest option i see it comes out very pixelated. if i click the match sequence settings to export it exports in hi def but it becomes a mpeg file instead of a mov file. I have never had this problem in the past i don’t know if its my adobe program or my Canon but i reset the camera to its factory settings and i still have this issue.
    If i chose a sequence setting that i don’t feel 100% about the preset is to export in 1920×1080 setting. i don’t know where I’m going wrong and i don’t want to just choose an option without knowing if I’m doing it correctly. Can anyone help me please and thanks in advance.
    Krystle Patino-serrano replied 11 years, 6 months ago 2 Members · 2 Replies
  • Daniel Waldron
    March 21, 2015 at 12:36 am
    Your sequence settings are fine. You are going about the export setting all wrong though. This article will give you a basic understanding of your export options.
  • Krystle Patino-serrano
    March 25, 2015 at 8:24 pm
    This article helped so much….Thanks again
