Activity Forums Adobe Premiere Pro exporting and preview issues
  • exporting and preview issues
    Posted by Victor Camacho guerrero on February 4, 2013 at 3:26 pm
    Hello everyone,
    in my work , I have a setup where connects Premiere to TV to preview the result. In the TV it looks fine, however when i preview in the monitor source in premiere, the quality is not great ( even with the display quality to full) , which i wouldnot mind so much, but we export this quality keep looking bad!! Even if I export with Maximum render quality ON.
    If I copy and paste to After Effect, the quality then is good and when I export is good as well.
    any idea?
    Many thanks!
    Victor Camacho guerrero replied 13 years, 7 months ago 2 Members · 2 Replies
  • Jeff Pulera
    February 4, 2013 at 6:56 pm
    Hi Victor,
    A lot more info is needed to address your problem.
    PC or Mac?
    Video source/format and sequence settings?
    Video card, and how is it connected to “TV” ?
    How does the video look bad – poor resolution, soft, grainy?
    Thank you
    Jeff Pulera
    Safe Harbor Computers
  • Victor Camacho guerrero
    February 5, 2013 at 9:49 am
    Hi jeff Thanks for your reply,
    It is a PC.
    I am working in a DV pal/ 720×576, aspect ratio 1.09, frames 25 sec
    I think the video card is a AJA Kona-SD Serial Digital Framestore. The way is connected is high technical, but as far as i know is based on matrix setup.
    I layoff to tape, which when i do, it does well, but when I export into quicktime or even uncompressed there is a pixelation and rasterization on the movie, result from exporting not all 100% quality.
    If you need more info, i could talk with the IT dept.
    Many thanks!!
